High priority How can i remove text from my house?
This topic has been viewed 4629 times and has 5 replies
noise694
Country: Portugal
Post by noise694 »
Hi, im new at sweet home 3d, i added a text to my house and now i can´t remove it. Can someone help pls?
Re: How can i remove text from my house?
Did you try to click on it to select it and choose Edit > Delete menu item?
Rickster55
Country: Canada
Post by Rickster55 »
I`m having the same problem. I tried clicking on the text, but nothing happens. It`s like there`s no object there. I even tried `Select All` which selects all the object, but no text.
Maybe it’s the name of a piece of furniture in which case you should unselect Display name in plan check box in its modification dialog box.
MarioSambol
Country: Croatia
Post by MarioSambol »
It sounds stupid if the text is in a locked level, if you use them
MarioSambol
Country: Croatia
Text is always on the base plan level. If the base plan is locked, the text cannot be selected. Unlock the base plan and then it is possible to select and delete the text. If you opened the furniture properties by double-clicking on the object, deselect the enabled option to show the name of the object.
