This topic has been viewed 4952 times and has 4 replies
Thread status:
Active
craigdabbs
- Country: Bodmin, CORNWALL, United Kingdom
Post
by craigdabbs »
Hi there,
I was hoping someone could point me in the right direction to get this program working in 3D mode, i can run the 2D version with no issues.
When launching the 3D version if errors out and writes a log file, it has a issue with libgl.
I can run glxgears to test the opengl on my laptop and it runs fine so im hoping its just a config issue between java and the 3d system.
log from sweethome3d
http://pastebin.com/WebNuEhY
glxinfo output -
http://pastebin.com/htdAfpKp
Hope someone can give some insight
Thanks
Craig
- Country: Netherlands
Post
by hansmex »
Craig,
Which version of which operating system are you using?
Have you read the
FAQ ?
craigdabbs
Post
by craigdabbs »
Sorry hans, i should off included that
Arch Linux 64, running KDE.
Post
by hansmex »
Craig,
My first try would be to
- uninstall IcedTea Java and
- install Oracle/Sun Java.
This solved some problems for me (Ubuntu 12.04) and
some others.
craigdabbs
Post
by craigdabbs »
I shall give that a go hans, thanks for replying i shall let you know how i get on.
