linux issues.
This topic has been viewed 22767 times and has 11 replies
xmastree
Country: Philippines
linux issues.
Post by xmastree »
Hi all, hoping someone can help here.
I had computer issues. I ended up installing linux and all's well.
However, when I installed SH3D, I noticed a slight difference in the way it behaves compared to the Windows version.
Compare these two images:
The first one was from when I was running Windows, the second one is the current view.
Is this just how things are in linux, or am I missing something?
The 3D view is fine:
Re: linux issues.
Select the Top view option in preferences pane.
xmastree
Re: linux issues.
Post by xmastree »
Thanks for your reply. I found the relevant section in the preferences, but it's greyed out.
https://imgur.com/i3ODoHR.png
UbuntuBirdy
Country: Switzerland
Re: linux issues.
Post by UbuntuBirdy »
Have you installed the latest video driver? If so, try installing another video driver. Have you installed the open source driver - try it with the proprietary one. Or vice versa.
Pascal
xmastree
Re: linux issues.
Post by xmastree »
I'm just using whatever driver came with the distro. It's Mint 19.3 and Intel video, not sure there are any other drivers available.
Re: linux issues.
Try the other script [font=courier new]SweetHome3D-Java3D-1_5_2[/font] provided with Sweet Home 3D installer.
xmastree
Re: linux issues.
Post by xmastree »
Other script? I don't see one. I installed it from the repo, using the software manager.
https://imgur.com/CWBU6LA.png
The version on the website seems much bnewer, I'll try that instead.
xmastree
Re: linux issues.
Post by xmastree »
Well, we appear to have a solution. I downloaded the latest version, 6.4.2, ran it using the other script, found the top view no longer greyed out and bingo!
Some textures missing, but that should be an easy fix.
Incidentally, just running ./SweethHome3D rather than ./SweetHome3D-Java3D-1_5_2 also seems to work correctly.
GerHas
Re: linux issues.
Post by GerHas »
I think I found the solution for the "greyed-out top" view icon problem.
/usr/share/sweethome3d/sweethome3d.sh script contains, upon install via repository, the java option:
-Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false
set it to true and top view icons behaves normally again.
Please let me know if I need report this to ubuntu launchpad or that this is the right channel
Re: linux issues.
[font=courier new]com.eteks.sweethome3d.j3d.checkOffScreenSupport[/font] is equal to [font=courier new]true[/font] by default. Why did they decide to set it to [font=courier new]false[/font]?!?
Setting it to [font=courier new]false[/font] is reserved for exceptional cases, like explained in the FAQ Sweet Home 3D crashes when I want to edit preferences, print, create a photo or create a video. What can I do?
Setting it to [font=courier new]true[/font] will remove some errors for a few users, but all the other users won't have top view icons or won't be able to the 3D view and generate photos at the two first quality levels (even if that could be replaced by screenshots if needed).
