X/Y Axis?
This topic has been viewed 1783 times and has 8 replies
A.D.STUDIO
- Member
- Country: Australia
X/Y Axis?
I'm wondering why I can't rotate an object on both its X- and Y-axis.
Re: X/Y Axis?
Because it’s generally too complex to guess the result of two rotations.
- dorin
Re: X/Y Axis?
Not ALL but furniture EXCEPT doors, windows and staircases.
Could be rotated on X, Y & Z axis.
Look at the piano .
Look at the piano .
Re: X/Y Axis?
Mmmm, "guess"? [:)]Because it’s generally too complex to guess the result of two rotations.
Separately the X and Y calculations are possible. Perform the Y calculation on the result of the X-calculation. You already have the code for both calculations. The only difference is that the Y calculation is done on the in-memory result of the X calculation. Or am I thinking too simple here?
That's basically what I do when needed: set the X angle, export, import, set the Y angle.
- dorin
Re: X/Y Axis?
I'm sorry!
You've right, I'm wrong!
When set X the Y become 0 and the opposite. Only Z (Angle) keep the value.
So, my answer is wrong. Sorry!
A.D.STUDIO
- Member
Re: X/Y Axis?
Thanks for the replies. Is there some technical reason why not? There's definitely use cases for it. I have a trapezoidal shaped box, need to lean it on its side and angle it up (it's an audio foldback wedge). Can't do it.
@Keet: are you saying I can set one axis, export and import and it's normalised at that position, then set the other axis? As a workaround...
Re: X/Y Axis?
Yes, that is what I do when I need a tilt on both X and Y. I first do one, export, import, and then do the other. It's not perfect because you have to export and import but the result is what you want with both tilts.@Keet: are you saying I can set one axis, export and import and it's normalised at that position, then set the other axis? As a workaround...
Re: X/Y Axis?
It's not a technical reason, it's for ergonomics reasons. Sweet Home 3D audience targets also people who don't understand how orientation around 3 axes work, moreover since these operations are not commutative.Is there some technical reason why not?
A.D.STUDIO
- Member
Re: X/Y Axis?
OK – I'd err on the side of offering complete functionality as opposed to crippling it to cater for the lowest common denominator, I don't think there's ever a good case for going that way. I think the picture you show of the three axes is pretty clear, too.
