MS10 / SH3D 6.5
Modify furniture
Change axis X and Y
How can I change both axis, X and Y at the same time?
I can only change X or Y, not both.
Modify furniture - Axis X and Y
This topic has been viewed 3323 times and has 5 replies
Re: Modify furniture - Axis X and Y
It's not possible, unless you reimport the 3D model and modify its orientation in the 2nd step of the importation wizard.
If you know the x and y that you require you open the modify furniture window and type them into the corresponding boxes.
Thank you for your post.
This procedure I know well, but it is very laborious.
For a complex roof I need more than 250 tiles, each on with a different X and Y axis.
I was hoping on version 6.5!
Kind Regards
Kind Regards
Sorry dear Mike.
You can only change X or Y, not both on once.
Have a read through THIS this post Grufty, it may help
