Trapezoid Window
This topic has been viewed 4510 times and has 4 replies
manishlulla
Country: United States
Trapezoid Window
Post by manishlulla »
Hi All Power Users,
I am trying to find how to put trapezoid windows in my model. Need to be able to change the dimensions as each window is a different size.
Thank you very much in advance.
Manish
https://www.pinterest.com/pin/201958983 ... iSxvjWrFzb[/img]
Country: UK
Re: Trapezoid Window
Post by Mike53 »
Whether you have made them yourself or downloaded them from elsewhere, during the import process you need to select (checkbox) that the object will be a door or window, once you have done that it should fit correctly into the wall and still enable you to modify the dimensions
manishlulla
Hi Mike,
Thank you.
I am a newbie, didnt follow your note.
I want to create a trapezoid window, I cant find a trapezoid window object for SweetHome3D. All windows are square. Thank you.
Post by VeroniQ »
There were some special windows in this article. Maybe they could feet...
manishlulla
Excellent, Thank you very much!
Will try these out.
