Hi All Power Users,
I am trying to find how to put trapezoid windows in my model. Need to be able to change the dimensions as each window is a different size.
Thank you very much in advance.
Manish
https://www.pinterest.com/pin/201958983 ... iSxvjWrFzb[/img]
Trapezoid Window
This topic has been viewed 4309 times and has 4 replies
Re: Trapezoid Window
Whether you have made them yourself or downloaded them from elsewhere, during the import process you need to select (checkbox) that the object will be a door or window, once you have done that it should fit correctly into the wall and still enable you to modify the dimensions
manishlulla
- Country: United States
Hi Mike,
Thank you.
I am a newbie, didnt follow your note.
I want to create a trapezoid window, I cant find a trapezoid window object for SweetHome3D. All windows are square. Thank you.
Thank you.
There were some special windows in this article. Maybe they could feet...
manishlulla
Excellent, Thank you very much!
Will try these out.
Will try these out.
