hello
first sorry for my bad english! ( hope you can understand it )
when i start SweetHome3D this error:
./SweetHome3D
Java 3D ERROR : GLX extension is not supported
GLX version 1.3 or higher is required
javax.media.j3d.IllegalRenderingStateException: Can't create graphics environment for Canvas 3D
picture like this: http://www.imgimg.de/bild_errord0814205png.png.html
my system:
opensuse 10.3
what is wrong?
what for information do you need?
can not start SweetHome3D - error not support
This topic has been viewed 6187 times and has 2 replies
tobias_mueller
Re: can not start SweetHome3D - error not sup
I hope this helps:
Go here for info on OpenGL: http://en.wikipedia.org/wiki/Opengl
scroll down to where it says, "Associated utility libraries" and get all the packages mentioned that you can find. I have packages like, freeglut, sdl, and xorg-x11-server-glx and things like that on my system. They may have changed the names of the packages by now, I don't know (I'm running SuSE 10.0 - it's considered to be old).
Olaf_Noehring
Re: can not start SweetHome3D - error not support
Hi
you should use the latest driver for your graphics card.
In case you are using a TFT monitor, check out this (http://www.rarst.net/software/cleartype ... -java-bug/) or this (http://www.team-noehring.de/php/cmsmade ... turnid=219) which might point you into a good direction.
Olaf
Olaf
