I can use it before, but then it start with Fatal error on windows 7
This topic has been viewed 5360 times and has 3 replies
im using laptop windows 7, hd 3000, 4gb ddr3 memory, directx 11, java version 8 update 74, it say "Sweet Home 3d will exit now because of fatal error in the 3d rendering system of you computer. Please update the Directx/OpenGL drivers of your computer graphic cards". I already use it before, but why now i cant use it anymore, please someone anwers, i really thankfull for ur answer
Re: I can use it before, but then it start with Fatal error on windows 7
i have the same problem
I ran into this issue under a different OS (XP) when running on a system with multiple monitors -- in my case, 3 -- driven by two different video cards. With earlier versions of SH3D (I believe this cropped up during the transition from 4.6 to 5.0) I could use all 3 monitors without issue, but with the newer version the application closed immediately after opening. I realized the 3D window was open and overlapped slightly onto the third monitor -- and something about the upgrade didn't play nicely with the drivers running that screen. Once I figured that out, I disabled that monitor from within Windows and restarted SH3D; it drew all windows entirely on the first two monitors. After closing SH3D and re-enabling the third monitor, subsequent attempts to use the application succeeded. That's probably not your issue -- but just in case, I thought I'd mention it.
Of course, I also have another machine where SH3D once worked but now simply shuts down with no error, despite everything I've tried....
Now i'm using the 3.6 portable version. It works fine.. Still the 5.2 exit with fatal error
