I hope I'm in the correct section. Does anyone know how to fix this? I had to disable my embedded AMD Radeon Graphic GPU (no supported drivers for Win 10 or Win 11) and go with just the onboard Intel GPU.
Error Message: LoadLibrary failed with error 1114 A dynamic link library (DLL) initialization routine failed
I know it has something to do with me disabling the AMD GPU but I can't enable it without crashes. It's an older laptop computer I'm just trying to get to run SH3D v6.6 again. It worked fine prior to the Win 11 update and I was running Win 10 on some odd drivers that I somehow got to work under Win 10 but not Win 11.
Any help will be really appreciated.
Error message when I try to start SH3D
This topic has been viewed 6913 times and has 2 replies
Re: Error message when I try to start SH3D
SOLVED!
I reinstalled the "Display Device" (AMD Radeon 6700M) in Device Manager that was giving me problems because there was no working Windows 11 driver and then removed it again and let Windows install the adapter as a "Basic Microsoft Adapter" and then disabled it. It appears Windows 11 needed to see the switchable graphics cards but only needs to use one. Hopefully that all made sense. Seems to be working as it did in Windows 10.
This will be helpful to some people.
