confused Sweet Home 3D Viewer - wo hakt es?
This topic has been viewed 3760 times and has 1 replies
TomcatMJ
Country: Cologne, NRW, Germany
Post by TomcatMJ »
Hallo Forum!
Der Sweet Home 3D Viewer (Versionen 3.0 und 3.1 probiert) hat mir nach einer Versuchsinstallation auf meinem V-Server folgende Fehlermeldung in der Javakonsole gegeben:
17.02.2011 05:56:36 javax.media.j3d.NativePipeline getSupportedOglVendor
SCHWERWIEGEND: java.lang.UnsatisfiedLinkError: no j3dcore-ogl-chk in java.library.path
java.lang.UnsatisfiedLinkError: no j3dcore-d3d in java.library.path
	at java.lang.ClassLoader.loadLibrary(Unknown Source)
	at java.lang.Runtime.loadLibrary0(Unknown Source)
	at java.lang.System.loadLibrary(Unknown Source)
	at javax.media.j3d.NativePipeline$1.run(NativePipeline.java:231)
	at java.security.AccessController.doPrivileged(Native Method)
	at javax.media.j3d.NativePipeline.loadLibrary(NativePipeline.java:200)
	at javax.media.j3d.NativePipeline.loadLibraries(NativePipeline.java:157)
	at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:987)
	at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:299)
	at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicsConfigTemplate3D.java:321)
	at java.awt.GraphicsDevice.getBestConfiguration(Unknown Source)
	at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Unknown Source)
	at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Unknown Source)
	at com.eteks.sweethome3d.applet.ViewerHelper.addComponent3DRenderingErrorObserver(Unknown Source)
	at com.eteks.sweethome3d.applet.ViewerHelper.<init>(Unknown Source)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
	at java.lang.reflect.Constructor.newInstance(Unknown Source)
	at com.eteks.sweethome3d.applet.SweetHome3DViewer.createAppletApplication(Unknown Source)
	at com.eteks.sweethome3d.applet.SweetHome3DViewer.init(Unknown Source)
	at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
Somit ließ sich leider meine sh3d-Datei nicht im Viewer anzeigen. Nun frage ich mich natürlich: Fehlt was auf meinem Server was zusätzlich zum heruntergeladenen ZIP-File und meiner sh3d Datei noch dort installiert werden muss oder hakts lokal auf den Clientrechnern?
Die verwendete Oracle Java Runtime Engine Version ist 1.6.0_23 auf meinem Windowsclient wo wenigstens die Fehlermeldung zu finden war und auf den Linuxclients die ich ebenso mal ausprobiert habe läuft java-1_6_0-sun-1.6.0.u23-0.2.1.x86_64 und dort lädt er nach einer Ewigkeit angeblich das Haus und wird selbst nach 2 Tagen noch immer nicht damit fertig.... [:-/]
Leider bin ich kein Progger und stehe damit nu mit dem Versuch das Problem zu lösen ein wenig dumm in der Gegend herum. Hat jemand von euch eine Idee wo es da haken könnte und wie ich das Problem gelöst bekommen kann?
Danke im Voraus,
Tom
P.S.:Meine beiden anderen Probs packe ich dann mal in neue Threads,denn ein Problem,ein Thread [:)]
"The social dynamics of the net are a direct consequence of the fact that nobody has yet developed a Remote Strangulation Protocol." -- Larry Wall
TomcatMJ
Re: Sweet Home 3D Viewer - wo hakt es?
Post by TomcatMJ »
Fortsetzung folgt in englsicher Sprache hier im entsprechenden Unterforum
