Integrating Sweet Home 3D Viewer in a webpage
This topic has been viewed 6831 times and has 13 replies
KenowaX
Country: Erquelinnes, Hainaut, Belgique
Post by KenowaX »
I'm using an online web creation service which allows me to upload files to my website but does not allow me to insert the files into folders.
Therefore, all my files for Sweet Home 3D Viewer are in the following URL : www.mywebsite.com/files/theme/
Having uploaded the files to the theme folder (no other folders possible) I changed the HTML script as follows to add the applet to my website :
   SweetHome3DViewer.html 31 Mar 2009
   Sweet Home 3D, Copyright (c) 2009-2013 Emmanuel PUYBARET / eTeks <[email protected]>
   This program is free software; you can redistribute it and/or modify
   it under the terms of the GNU General Public License as published by
   the Free Software Foundation; either version 2 of the License, or
   (at your option) any later version.
   This program is distributed in the hope that it will be useful,
   but WITHOUT ANY WARRANTY; without even the implied warranty of
   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
   GNU General Public License for more details.
   You should have received a copy of the GNU General Public License
   along with this program; if not, write to the Free Software
   Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
<script language="JavaScript" src="http://java.com/js/deployJava.js">
</script>
<script>
  var javaMinimumVersion = "1.6.0_10"; // The first version with Java Plugin 2
  var jars = "files/theme/SweetHome3DViewer.jar,files/theme/batik-svgpathparser-1.7.jar";
  // Append Java 3D Jars depending on the platform
  if (navigator.platform.match("Win.*")) {
    if (navigator.platform.match(".*64")) {
      jars += ",files/theme/java3d_windows_x64.jar";
    } else {
      jars += ",files/theme/java3d_windows_i386.jar";
  } else if (navigator.platform.match("Mac.*")) {
    javaMinimumVersion = "1.5";
    jars += ",files/theme/java3d_macosx.jar";
  } else if (navigator.platform.match("Linux.*")) {
    javaMinimumVersion = "1.6"; // OpenJDK doesn't give its subversion
      jars += ",files/theme/java3d_linux_x64.jar";
    } else {
      jars += ",files/theme/java3d_linux_i386.jar";
  } else {
    jars += ",files/theme/java3d.jar";
  var attributes = {codebase:"http://shibu-q.weebly.com/files/theme/",
                    code:"SweetHome3DViewer.jar",
                    archive:jars,
                    width:"100%", height:"100%",
  var parameters = {java_arguments:"-Xmx640m",
                    navigationPanel:"true",
                    homeURL:"http//shibu-q.weebly.com/files/theme/default.sh3d",
                    // JNLP file converted to Base 64 encoding with "base64 -i SweetHome3DViewer.jnlp" command
                    jnlp_embedded:"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"};
  deployJava.setInstallerType("kernel");
  deployJava.setAdditionalPackages("javax.swing,javax.imageio");
  deployJava.runApplet(attributes, parameters, javaMinimumVersion);
</script>
However, when I try to launch the app on my website, I get the following error :
That is normal since the file is not in the lib folder. It is in the theme folder.
Is there any way to fix this ?
Thank you,
Re: Integrating Sweet Home 3D Viewer in a webpage
Actually, the changes you made on the value of the jars variable and codebase attribute have an effect only with Java 6. Under Java 7 and further, I think that the JRE always uses the jnlp_embedded parameter after decoding it from Base 64.
As the jnlp_embedded parameter proposed in the default configuration tries to download jar files from lib subfolder, that would explain the error you reported. To fix it, you should download the SweetHome3DViewer.jnlp file that was used to generate the current value of the jnlp_embedded parameter, update the href attribute of its <jar> elements with a text editor and save it. Then, convert the modified file to Base 64 and copy the encoded string in jnlp_embedded parameter.
By the way, there must be a typo in your homeURL parameter where a colon is missing after http.
KenowaX
Post by KenowaX »
Thank you for your reply.
I tried what you suggested. However, now, the app doesn't even show up on the website.
I got the following code from the BASE64 encryption :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I got the code by encrypting this text file :
<?xml version="1.0"?>
Sweet Home 3D, Copyright (c) 2013 Emmanuel PUYBARET / eTeks <[email protected]>
02111-1307  USA
Accompanying JNLP file for Sweet Home 3D Viewer.
Should match the applet script in SweetHome3DViewer.html and used
as its jnlp_embedded parameter value after a conversion to base64.
Under Unix, conversion to base64 can be done with the following command:
<jnlp href="SweetHome3DViewer.jnlp">
<information>
<title>Sweet Home 3D Viewer</title>
<vendor>eTeks</vendor>
<homepage href="http://www.sweethome3d.com/"/>
</information>
<security>
<all-permissions/>
</security>
<resources>
<j2se version="1.5+" max-heap-size="640m"/>
<jar href="SweetHome3DViewer.jar" main="true"/>
<jar href="batik-svgpathparser-1.7.jar"/>
<property name="jnlp.packEnabled" value="false"/>
</resources>
<resources os="Windows" arch="x86">
<jar href="java3d_windows_i386.jar"/>
</resources>
<resources os="Windows" arch="amd64">
<jar href="java3d_windows_x64.jar"/>
</resources>
<resources os="Mac OS X">
<property name="apple.awt.graphics.UseQuartz" value="true"/>
<property name="j3d.rend" value="jogl"/>
<jar href="java3d_macosx.jar"/>
</resources>
<resources os="Linux" arch="x86 i386">
<jar href="java3d_linux_i386.jar"/>
</resources>
<resources os="Linux" arch="amd64 x86_64">
<jar href="java3d_linux_x64.jar"/>
</resources>
<resources os="SunOS">
<extension href="http://download.java.net/media/java3d/webstart/release/java3d-1.5-latest.jnlp"/>
</resources>
<applet-desc main-class="com.eteks.sweethome3d.applet.SweetHome3DViewer"
               name="SweetHome3DViewer" width="600" height="600"/>
</jnlp>
Could you help me, please ?
KenowaX
Post by KenowaX »
Alright, I managed to code it right.
Apparantly, it needed to be encoded with a certain character encryption.
Anyway, now I have another problem.
The app loads correctly. But after loading, it stays blank or I get a JNLP Signing Exception error.
It reads "Cannot validate signature of the launch file. The version signed does not correspond to the version downloaded."
KenowaX
Post by KenowaX »
I've tried to see where this error could come from.
Apparently, just modifying a tiny bit the jnlp file then converting it generates this error.
That is quite bothering if I cannot modify this file...
I have no idea of how the Java signatures work.
KenowaX
Post by KenowaX »
I've tried to modify the SweetHome3DViewer.jar and changing the JNLP file inside it.
Now I get a NullPointerException.
I forgot about the JNLP file in the SweetHome3DViewer.jar that should match the one you change. Updating it in the jar file isn't enough, you will have also to sign again all the jars with your own software certificate to make it work. If you don't have a certificate, you may try also to simply remove the JNLP file from SweetHome3DViewer.jar. I think it will work but the JRE will display a warning.
KenowaX
Post by KenowaX »
Alright, I tried what you suggested.
I get a ClassNotFoundException error.
It says the class com.eteks.sweethome3d.applet.SweetHome3DViewer cannot be found.
This is strange as it is in fact inside the JAR file...
KenowaX
Post by KenowaX »
I forgot to mention what I actually did.
Since I don't have any certificates, I tried removing the JNLP.
I removed the JNLP folder in the JAR and I removed every references to the JNLP file from the MANIFEST file inside the META-INF folder.
After this, I repacked the JAR file.
I removed the references to the JNLP from the HTML file and tried to load it.
After the app has loaded, I get the error previously mentionned.
KenowaX
Post by KenowaX »
In case you need the codes, here they are :
</script>
<script>
  var jars = "SweetHome3DViewer.jar,batik-svgpathparser-1.7.jar";
      jars += ",java3d_windows_x64.jar";
    } else {
      jars += ",java3d_windows_i386.jar";
    jars += ",java3d_macosx.jar";
      jars += ",java3d_linux_x64.jar";
    } else {
      jars += ",java3d_linux_i386.jar";
  } else {
    jars += ",java3d.jar";
                    code:"SweetHome3DViewer",
                    archive:jars,
                    homeURL:"http://shibu-q.weebly.com/files/theme/default.sh3d"};
</script>
