Hi
I have a MacBook Pro (M3 Max, 36 GB) running on Mac Os Sonoma 14.1.
After switching to this device, I ran into issues with not being able to open recent projects I did on the previous computer. Though I was able to open older projects and even doing new projects.
After running through all the usual hustle with deinstalling, killing all files, clean up and so forth, I now have a new download from your website (I also had the paid version from app store, but was using it with a different apple id). Whenever I try to "view in separate window" it freezes instantly and the rainbow wheel of death keeps on spinning until i force quit.
Please help. I'm using SH3D for over ten years now and it's a crucial part of my business.
Open for questions and any help.
Thanks for your support
View in separate window freezes my Mac
This topic has been viewed 5953 times and has 6 replies
Re: View in separate window freezes my Mac
If you use a second monitor, turn in off while you open the file.
I would also recommend to update your system to the last Sonoma version.
silvanschaad
Thanks Emmanuel for your reply.
I did some more research on second screen behaviour and I looks like this is causing the wheel of death.
Fact is that a second monitor is crucial to have because on a 14" macbook I can't work for hours and don't have enough room for details nor overview.
So considering this I and your advice, the performance on the macbook without second screen was close to before. Mostly running without any issues no matter what I was doing.
I also changed the way I wired up the second monitor. Previously mostly with an external adapter, but now also with the direct html input. I couldn't see a mayor difference though...
What brought the solution for now (still testing and observing) is changing the lead monitor within system settings. I had chosen the macbook and changed now to the second monitor which basically solves the problem.
So prior to my old setup with an older intel-based macbook this seems to be a newer setting that you can make and that might cause these problems...
I'm not sure but your issue looks like Florent's one reported in bug ticket #1259.
Could you try the version 7.3a available here to check if it works better in your case?
Any news about the version 7.3a I proposed?
I released the version 7.4 with the correction proposed in ticket #1259.
Hope it will fix your issue...
silvanschaad
Hi Emmanuel
I use 7.3.1 and it works. But I guess the game changer has been changing the lead monitor to my external big screen...
You can close this thread for now.
