High priority View in separate window freezes my Mac
This topic has been viewed 5955 times and has 6 replies
silvanschaad
Post by silvanschaad »
Hi
I have a MacBook Pro (M3 Max, 36 GB) running on Mac Os Sonoma 14.1.
After switching to this device, I ran into issues with not being able to open recent projects I did on the previous computer. Though I was able to open older projects and even doing new projects.
After running through all the usual hustle with deinstalling, killing all files, clean up and so forth, I now have a new download from your website (I also had the paid version from app store, but was using it with a different apple id). Whenever I try to "view in separate window" it freezes instantly and the rainbow wheel of death keeps on spinning until i force quit.
Please help. I'm using SH3D for over ten years now and it's a crucial part of my business.
Open for questions and any help.
Thanks for your support
Re: View in separate window freezes my Mac
If you use a second monitor, turn in off while you open the file.
I would also recommend to update your system to the last Sonoma version.
silvanschaad
Thanks Emmanuel for your reply.
I did some more research on second screen behaviour and I looks like this is causing the wheel of death.
Fact is that a second monitor is crucial to have because on a 14" macbook I can't work for hours and don't have enough room for details nor overview.
So considering this I and your advice, the performance on the macbook without second screen was close to before. Mostly running without any issues no matter what I was doing.
I also changed the way I wired up the second monitor. Previously mostly with an external adapter, but now also with the direct html input. I couldn't see a mayor difference though...
What brought the solution for now (still testing and observing) is changing the lead monitor within system settings. I had chosen the macbook and changed now to the second monitor which basically solves the problem.
So prior to my old setup with an older intel-based macbook this seems to be a newer setting that you can make and that might cause these problems...
I'm not sure but your issue looks like Florent's one reported in bug ticket #1259.
Could you try the version 7.3a available here to check if it works better in your case?
Any news about the version 7.3a I proposed?
I released the version 7.4 with the correction proposed in ticket #1259.
Hope it will fix your issue...
silvanschaad
Hi Emmanuel
I use 7.3.1 and it works. But I guess the game changer has been changing the lead monitor to my external big screen...
You can close this thread for now.
