3D View "Display In Separate Window" Causes Hangs
This topic has been viewed 10588 times and has 13 replies
A.D.STUDIO
Country: Australia
Post by A.D.STUDIO »
Thanks for the 7.4 update. There's a note about separating the 3D view on a separate monitor would cause freezes but now fixed. However, I separate this window on a single monitor and I can guarantee a hang after toggling around six times. This is with ONE model in the plan.
A.D.STUDIO
Country: Australia
Re: 3D View "Display In Separate Window" Causes Hangs
I think there's a severe memory leak going on, my RAM is maxed out after doing this...
dorin
Post by dorin »
Thanks A.D.STUDIO!
I've encountered the same problem even I'm under linux (debian) on both computers (at work and at home).
Symptoms: SH3D don't start even with an empty file.
Result in konsole:
library initialization failed - unable to allocate file descriptor table - out of memory
Solution for linux users found on the net:
What fixed it was this command as root (su -) (sudo didn't do it):
echo >/etc/security/limits.d/systemd.conf "* hard nofile 1048576"
Then reboot.
Solutions found here and here .
I hope it will help someone.
I was able to reproduce this issue by using the shortcut for Display in separate window / Display in main window menu items (Ctrl + Alt + Y) many times quickly. Andy, is it what you tried on your side?
I found it wasn't a memory leak issue, but rather a problem of synchronization between separate / not separate state of the 3D view. Anyway, I fixed it and the correction will be available in the next version.
A.D.STUDIO
Country: Australia
@Puybaret, yes that is exactly what has been happening to me. Thank you for looking into it and I look forward to the update.
Don’t expect an update too soon and meanwhile, avoid attaching / detaching the 3D view too quickly.
A.D.STUDIO
Country: Australia
Would you consider releasing a beta or something for me to test? I'm not actually toggling that fast and have a presentation in a week.
Is it so difficult to refrain yourself from toggling detached 3D view?!?
Or maybe your project is huge or it’s another issue.
By the way, I noticed that the program didn't hang. If you click in the main window, it will activate it and you can continue to use it.
A.D.STUDIO
Country: Australia
OK well it hangs for me. Not sure why you'd offer detached 3D view if you don't think people should use it. I'm on a single screen, and because it can be done with a key command, I can go full screen 3D with a button press, and back again, which is actually quite convenient.
