This topic has been viewed 3380 times and has 9 replies
Thread status:
Active
Jo_Alfemo
Posts: 7 Joined: Mon Jul 16, 2018 6:45 pm
Post
by Jo_Alfemo » Sat Dec 18, 2021 5:23 pm
in a project I'm doing, the ceiling is not close to the walls. What can it be? How can I solve?
Image1 by
José Monteiro , no Flickr
Thanks in advance
Posts: 9440 Joined: Mon Nov 07, 2005 12:00 pm
Post
by Puybaret » Sat Dec 18, 2021 5:35 pm
You must have created more than one level and didn't set a height for the level matching the height of your walls. The height of a level is used to know the elevation of ceilings (except for the last level).
Jo_Alfemo
Post
by Jo_Alfemo » Sun Dec 19, 2021 9:08 am
Hi Puybaret.
Do you mean I have to eliminate the second level and build that level again? Actually initially I just copy/paste to add the second level.
Tks for help
Post
by Puybaret » Sun Dec 19, 2021 4:33 pm
Don't delete anything, just select the first level and modify its height in the level modification dialog box.
Jo_Alfemo
Post
by Jo_Alfemo » Sun Dec 19, 2021 6:50 pm
Here?
Post
by Puybaret » Sun Dec 19, 2021 7:04 pm
Yes
Post
by Puybaret » Mon Dec 20, 2021 6:52 pm
Add a dummy level, because slanted ceilings are computed only at the last level.
Jo_Alfemo
Post
by Jo_Alfemo » Tue Dec 21, 2021 5:28 pm
dummy level???
Post
by Puybaret » Tue Dec 21, 2021 5:31 pm
By "dummy", I meant a level that you won't actually use, but that will change the algorithm which computes ceiling at the before last level.
