love struck How do I close my walls?
This topic has been viewed 3513 times and has 3 replies
function10
Post by function10 »
When I draw 4 walls, how can I get the ending of wall 4 to neatly fit with the starting point of wall 1?
Looking at the image below, my problem is the left hand corner. The right hand corner is not boxy. The right hand side corner is an automatic join when I click several times to place multiple walls.
Re: How do I close my walls?
Double click on the start point (the starting wall will be colored when you approach it), or afterwards, use the Plan > Join walls menu item (see this article).
Select the two walls you want to connect, right click, and choose 'Join walls' from the context menu.
function10
Thank you Puybaret & Keet.
I did not see that info here: https://sweethome3d.com/userGuide.jsp#drawingWalls
