hello to all,
I started to draw a project without noticing that the wall height is set to 250cm instead of 290cm. May I raise all the existing walls and the ceiling to 290cm at once?
thanks,
Marco
raising existing walls and ceiling
This topic has been viewed 9652 times and has 4 replies
Re: raising existing walls and ceiling
Hello Bigjim.
Select your whole design in Plan with Ctrl A (or cmd A on masOS), then Plan > Modify wall and change the height. Only your walls will be changed. If you have only one level, the ceiling will adjust itself at 290 cm. If you need a level, you can read this blog article .
thank you!
HananeBelyekdoumi
- Country: Canada
Is there a way to raise the walls in the online version of sweet home 3d? I was also wondering if there is a way to put a roof in the online version.
The Online version isn’t finished, and you’ll have to be patient before these features become available. If you need them, I would suggest to export your online design and modify it with the installer version.
