Hello, everyone,
I would like to make a round room cutout of 180 cm on the first floor, so that one can see a sculpture in the basement.
Can someone please help me in a friendly manner?
Thanks!
I need a little help!
This topic has been viewed 1876 times and has 2 replies
- oldies2000
- Contact:
Re: I need a little help!
The metod is similar as shown in this tip, but for cutting floors you need a dummy element imported as a staircase, not door or window.
I've just uploaded a file with two elements like this I'd made for myself - see here. This is a library file, so import it as library and you'll find a cutting cylinder and a cutting cube in a folder named "construction". Put the cylinder in the basement and elevate it so it goes through the ceiling, then you should see a hole on the first floor. Resize the cylinder and modify the material to invisible.
- oldies2000
- Contact:
Thanks for the support, everything worked out fine!
Best regards from Germany
