Need a little help.!
This topic has been viewed 4192 times and has 9 replies
sree.arun.kr
- Country: Kerala, Kerala, INDIA
Hello Sir,
Recently I faced a situation like I need to restore my windows to an old restore point, after it I re-installed java JRE 7 to JRE 8. Now on start up SH3D hanging my system like it uses real time priority and took 40 sec to 1 min for full loading.Also when I rotate 3d view it skips frames like a high end game runs in slower system.And also when the application closed the SH3D window disappears but it runs in background I need to end the process through task manager.(If does not drawn or changed anything it closes perfectly).
Re installing java or increasing -Xmx1024m to -Xmx1280m does not solved.
My system configuration is Windows 7 SP1 32bit,with 2GB RAM and 2GB GPU memory.
Re: Need a little help.!
What version do you run? The installer version or the Java Web Start version?
sree.arun.kr
SH3D Installer version 4.4 and also SH3D 4.5beta6(web start?. I don't know.!) jp2launcher.exe failed to close.Not all the time but most. [:-?]
The Beta version is running with Java Web Start and the JRE you installed.
The installer version works with a private copy of a JRE 6.
Do you see the same issues with both versions?
sree.arun.kr
Less frame rate while rotating is only with installer version.
But application failed to closed is in both version.I mean when draw something and closed without saving or working with a big project(I am not sure exactly how.) [8-|]
Does the problem appear on any home?
sree.arun.kr
I don't get you.Does the problem appear on any home?
What do you mean by 'any home'.
Looks like its a problem related with SH3D and java because the closing bug happens in older installer version 4.3 also. [#-o]
sree.arun.kr
Yes.
Here attached a sample file (but i don't think it will solve the issue).
1. Open SH3D 4.4 installer version.
2. Loaded a file from resent/history.
3. Just rotated scene (frame skipping bug)
4. Changed time in photorenderer.
5. Saved the rendered image.
6. SH3D closed without saving.
7. 5 minute later open Task manager and it shows sh3d running background.(Runs in background bug) [:-&]
- Attachments
- test.1.zip
- (557.9 KiB) Downloaded 649108 times
sree.arun.kr
