I downloaded SweetHome3D Linux version, where it runs without installation (just unpack and launch SweetHome3D script)
The application it self runs without problem.
As next step I wanted to add some the Plugin.
Here [url=http://]http://www.sweethome3d.com/pluginDeveloperGuide.jsp[/url]
I have read, that plugins should be added here:
.eteks/sweethome3d/plugins of your user folder.
In my case the subfolder plugins was not there, so I created it
As next step I downloaded this plugin:
[url=http://]https://sourceforge.net/p/sweethome3d/p ... Volume.rar[/url]
and placed to the recommended folder:
I started the application, but in menu I do not see some new section ..like the Tool.
What I do wrongly?
Thanks for any hint!
ZAJDAN
Install pugin in Linux version
This topic has been viewed 6089 times and has 5 replies
Re: Install pugin in Linux version
I guess you are trying to install the plug-in #8. You should copy TheRestOfTheFurnitureInTheRoomplugin.jar file in [font=courier new].eteks/sweethome3d/plugins[/font] folder rather than the RAR file which contains the source code of the plug-in.
Of course, This is logic, that we have to unpack and place there the content of the package. Exactly this I made.
But in the case of the plugin which I wanted to it is RAR.
1) I downloaded the package
2) Unpacked
3) The content I placed into the mentioned directory
look here:
2) Unpacked
look here:
ls /home/zoja/.eteks/sweethome3d/plugins/
/home/zoja/.eteks/sweethome3d/plugins/RemainderPlugin.javaRe: Install pugin in Linux version
Maybe my message wasn't clear enough: Do not copy [font=courier new]RemainderPlugin.java[/font] it won't work. Copy [font=courier new]TheRestOfTheFurnitureInTheRoomplugin.jar[/font] in [font=courier new]/home/zoja/.eteks/sweethome3d/plugins/[/font]
Thank You...
TheRestOfTheFurnitureInTheRoomplugin.jar works. But the plugin about which I spoke I thought will be able count cubic meters of walls. Exist some such pluging to get m³ of wall?
Thanks for this
