SH3D & Tools linux install & config -my way
This topic has been viewed 136964 times and has 15 replies
dorin
Post by dorin »
Hardware at work (home):
CPU= INTEL Core2duo (I7 gen 3)
Mem. DDR3= 4G (8G)
Dedicated Graphic card= none
System:
debian netinstall + KDE desktop
Preparation
Download from surgeforge.net:
- sweethome3d 64bit;
- Furniture Library Editor;
- optional Furniture Library Editor with ID;
- Texture Library Editor;
- Huge File Cleaner;
I Installation
1. Make a new folder in user home (or whatever) name „Sweet Home”(or whatever) :
1.1 Extract in it SweetHome3D-6.3-linux-x64.tgz; You will have a new folder „SweetHome3D-6.3”;
1.1.1 In this new folder double click on SweetHome3D file and choose „Execute”; Will show up a new SH3D project;
1.1.2 Go to „settings” and modify something there useful for You (like unit dimensions, wall thickness, You name it);
This action will create in Your home the hidden folder „ .eteks” and other sub folders;
Now You have a basic working SH3D.
2. In the „Sweet Home” folder create a new folder name “Editors”;
2.1 Go to “Editors” and create also a new folder name “editors”;
2.2 Move the 3(4) jar files of editors from Downloads to Editors/editors;
2.3 Open SweetHome3D-6.3 and copy jre8 folder to Editors;
2.4 Create a separate text file for every editor You want to launch in Editor folder with this text inside accordingly with individual jar file like this:
#!/bin/sh
# Retrieve Furniture Library Editor directory
PROGRAM=`readlink "$0"`
if [ "$PROGRAM" = "" ];
 then
PROGRAM=$0
fi
PROGRAM_DIR=`dirname "$PROGRAM"`
# Run Furniture Library Editor
exec "$PROGRAM_DIR"/jre8/bin/java -jar "$PROGRAM_DIR"/editors/FurnitureLibraryEditor-1.25.jar
and save it with corresponding name;
Make it executable.
Verify if work.
Verify also throw Help→About or similar and You could see this:
Image Image Image
If all this work fine until now You could go to next chapter.
II Customization
1. Set the defaults for sh3d files:
1.1 Right-click on start button and choose Edit Application…
1.2 Under Graphics menu add a new entry like this:
Save and close.
2. Click on start and choose System Settings→Applications→File Associations
2.2 On applications +Add… , insert a name (sweethome3d)
2.3 On Edit set the Filename patterns, icon, description and the applications
2.4 For application and icon You have to navigate to
/home/user-name/Sweet Home/SweetHome3D-6.3/SweetHome3D
/home/user-name/Sweet Home/SweetHome3D-6.3/SweetHome3DIcon.png
2.5 Sommeting like this:
Apply and close.
3. Modify the default furniture
3.1 Go to SweetHome 3D-6.3→lib
3.2 Copy->Paste and rename the Furniture.jar file as Furniture-M.jar
3.3 Modify the Furniture-M as You wish and put it back in lib folder
3.4 Copy->Paste and rename the executable SweetHome3D file as SweetHome3D-M
3.5 Open SweetHome3D-M with an editor (e.g. kate) and modify
"$PROGRAM_DIR"/lib/Furniture.jar:
with
"$PROGRAM_DIR"/lib/Furniture-M.jar:
Save and close.
Make it executable (if is not already).
Run it to see what You’ve done.
I usually modify the category like split the lights in lights and lamps, mannequins goes to characters, some shapes from miscellaneous to basic shapes.
Most important for me is to add and set to every door or windows the statement:
doorOrWindowWidthDepthDeformable#1=false
Re: SH3D & Tools linux install & config -my way
Many thanks Dorin for these detailed instructions. I added a link to this thread in Download page.
AndresEOED
Country: United Kingdom
Post by AndresEOED »
For vanilla ubuntu gnome the following worked for me.
The execute step is the one shared in the downloads page by @puybaret
https://askubuntu.com/questions/286621/ ... n-nautilus
Following from here: https://howto-ubuntunew.blogspot.com/20 ... d-552.html on ubuntu you can create a desktop so that you can find it on dash.
$ sudo gedit /usr/share/applications/sweethome3d-6.3.desktop
[Desktop Entry]
Version=1.0
Name=Sweet Home 3D 5.5.2
GenericName=Interior 2D design application with 3D preview
GenericName[de]=Innenraumplaner
Comment=Interior design Java application for quickly choosing and placing furniture on a house 2D plan drawn by the end-user with a 3D preview
Exec=/home/andres/SweetHome3D-6.3/SweetHome3D
Icon=SweetHome3DIcon
StartupNotify=true
StartupWMClass=com-eteks-sweethome3d-SweetHome3D
Terminal=false
Type=Application
Categories=Graphics;2DGraphics;3DGraphics;
Keywords=interior;design;2D;3D;home;house;furniture;java;
Special precaution on the Exec line as you might have used a different location. you can find the file mentioned in step 1.1.1 above and copy it. when you paste it in gedit it will past the full path, saves form typing mistakes.
for the icon right click in the folder where the png is located (again step 1.1.1. above).
$sudo cp SweetHome3DIcon.png /usr/share/icons/
AndresEOED
[Desktop Entry]
Version=1.0
StartupNotify=true
Terminal=false
Type=Application
For got to add at the end: in the file manager right click (open in terminal...)
otadmin
Post by otadmin »
Thank you Dorin for the detailled instructions. Followed and got SH3D 7 installed on LinuxMint 21. Newer version than in the repositories.
Now have to install Furniture & Texture editors. Your instructions say "2.3 Open SweetHome3D-6.3 and copy jre8 folder to Editors;". However in SH3D 7.1 there is no jre8 folder. Please new instructions.
dorin
Post by dorin »
@otadmin
I'm happy it is useful at least for you.
1. I recommend to have and use ONLY ONE version, the installer one NOT THE REPOSITORY ONE.
1.1 Also I prefer to have it all somewhere in my home folder than under /usr/.... but it's your choice.
2. Starting with SH3D-6.5 the jre8 folder was replaced with runtime.
So, copy the runtime folder and rename it as jre8 OR modify the path accordingly.
In my case I've downloaded the latest jre8 version for linux (jre1.8.0_351) and it appear to work.
Hope this is helpful.
I work almost exclusively through the file manager. I created a custom command to open .sh3d files from the file manager and that works fine. But the same doesn't work for the furniture and texture editors. The program is opened but not with the file I selected from the file manager. Any idea how to fix that?
dorin
Post by dorin »
Small update.
After points 2 to 2.5 (if all works well) add point
2.6 Create desktop shortcut for SH3D
2.6.1 Click Start -> Graphics;
2.6.2 Right-click on SweetHome3D entry and
2.6.3 choose +Add to Desktop
Will generate a desktop file.
Something like this:
This is under KDE with Dolphin. I like more Konqueror or Krusader as file manager but...
For other DE and file managers you have to discover the specific ways.
dorin
Post by dorin »
@Keet
Nope. I've tried in a classic way.
You've right: it open the application but without the file.
BUT wile
I don't edit everyday a furniture(texture) library I don't see the usage.
When I will have more time I'll see if & how to pass a file name to this applications.
Until then (for me) don't hurt to import desired library.
Or maybe you will find a bash solution and share with us.
PS Probably I've upset somebody again. Sorry!
Yep, I tried all classic ways too.
The strange thing is this works directly in the terminal:
java -jar /[path-to-editor]/FurnitureLibraryEditor-1.30.jar -open "/[my-SH3D-path]/furniture libraries/mylibrary.sh3f"
But when I translate that into this .sh script:
#!/bin/sh
java -jar /[path-to-editor]/FurnitureLibraryEditor-1.30.jar -open $0
It does open the editor but does not load the passed library file. That's something I can not explain. The $0 parameter should pass the file complete with path so I see no difference with putting it directly into the terminal.
