Web Start error message.
This topic has been viewed 24001 times and has 9 replies
Bob_Brazie
Ubuntu 9.04
When I go to the folder I have the sweethome application in and right click the SweetHome3D icon and choose to open with 'Sun Java 6 Web Start' I get a short Java 6 splash screen and then the message “Unable to launch application”.
If I am on the download page of SweetHome and click the “Launch SweetHome with Java web Start” it opens just fine. http://www.sweethome3d.eu/download.html.
I couldn't find anything in the FAQ section dealing with this.
Any help would be appreciated. Bob.
Re: Web Start error message.
Did you figure out the solution to your problem?
Did you download the application? If so, you don't need the Java Web Start and you don't need to right click. If you have Java installed correctly on your system, the app should launch when you click on the executable file named, "SweetHome3D" (without quote marks. In the "File Type" section of your file viewer, it should say that it is a "Shell Script")
Bob_Brazie
I have found that file but when I run the application and try to print or do anything in the file menu I get a fatal error in the rendering system message saying it needs to shut down.
Very frustrating.
Very frustrating.
Can you post the exact error message? Then maybe Emmanuel (the developer) might see it and tell you more.
I guess bbrazie's bug is the same as
https://sourceforge.net/tracker/?func=detail&aid=2811829&group_id=152568&atid=784665
But it should happen only for print and preferences menu items, not for File > Open and File > Save menu items.
Bob_Brazie
If I read the bug thread then it seems that there is no fix?
Yes, the bug is not fixed yet.
Sorry if I can't give you a better answer.
Bob_Brazie
That's OK. Thanks for the answer. Bob.
Has anyone found a solution to this problem? I have the same on Ubuntu 16.04
In case you didn't notice, this is a very old thread.
I would suggest to try [font=courier new]SweetHome3D[/font] or [font=courier new]SweetHome3D-Java3D-1_5_2[/font] scripts in Sweet Home 3D installer.
