confused High priority Error message: "Can't print Home "
This topic has been viewed 6583 times and has 7 replies
Loplop
Country: Italia
Post by Loplop »
Hi everyone!
I have a problem with the print area: when I go to print>create pdf or pdf preview, the message " Can't print Home" appears. Same if I go to Save as Post Script or send with mail. The message is the same with all the options I have in the pdf menu. I have a Mac but no problem at all with pdf in other softwares as Autocad or others.
Could it be a bug with the Mac OS Catalina?
Can anyone help me?
Many thanks in advance!!
Re: Error message: "Can't print Home "
The last time someone reported me this error, he fixed it by updating the drivers of his printer.
Loplop
Country: Italia
Post by Loplop »
Hi Emmanuel,
Thanks for your answer.
I don't have any printer. I used to create a pdf and send it via mail. The problem is not linked with the fact of printing but with the creation of the pdf. The software don't let me create a pdf format.
If someone has any idea...
Thanks!
Strange... I just tried without any printer installed and it worked without problem.
Loplop
Country: Italia
Post by Loplop »
Any suggestion? Is there any settings I can adjust in the software or in my Mac?
Do you think it can be liked with Catalina update?
Thanks!
It's not a problem in Catalina, I tried it under Mojave and Catalina.
The only suggestion that comes to my mind is to build your printed document yourself using other tools of Sweet Home 3D:
- select the items in the furniture list and copy/paste them in a spreadsheet application like OpenOffice,
- select all the plan and copy/paste it in Preview or any application able to handle images (why not OpenOffice again),
- create a 3D image with the photo creation tool and include the generated image in the document you want to print.
mike603
Country: USA
Post by mike603 »
I am experiencing the same problem on a Windows machine.
I have tried printing to 3 different printers so it's not a printer driver problem.
I will reboot and try again.
I am a paid user.
Did you try to print to PDF then print the generated PDF file?
