High priority Need to deploy on Tomcat serer
This topic has been viewed 23155 times and has 41 replies
prabath
Post by prabath »
Hi
I want to deploy sweethome3d jar on a server. Please tell me how to do that
Re: Need to deploy on Tomcat serer
What do you mean by deploying sweethome3d jar on a server? You want to try to deploy the online version on a web server? If it's the case, the source code and the search engine of the forum will give you many hints.
prabath
Post by prabath »
Thank you for your reply.
yes of Course. I want to deploy the online version and want to access through a browser. (like - http://www.sweethome3d.com/SweetHome3DOnline.jsp). Please help me to deploy this.
Thank you
prabath
Post by prabath »
Thanks for your Hint. I was able to set it up. When I set it up as a desktop application, application doen't allow me to save the designed floor plan. It says "Can't check if home exists".
Please help me.
prabath
Post by prabath »
Appreciate your reply...
Look at the javadoc and how it's deployed on sweethome3d.com. The following threads might help you too:
http://www.sweethome3d.com/support/foru ... hread,1113
http://www.sweethome3d.com/support/foru ... hread,1454
http://www.sweethome3d.com/support/foru ... hread,1435
http://www.sweethome3d.com/support/foru ... hread,2608
There's no other documentation about this subject, but feel free to write one if you want.
prabath
Post by prabath »
Thanks Putybert.
prabath
Post by prabath »
Hi Mr Puybaret
I want to load the Floor Plan directly. All Parameters should be set internally. Please tell me how to do it.
Thank YOu
prabath
Post by prabath »
You should set the floor plan you want in the applet parameter named defaultHome.
