Need to deploy on Tomcat serer
This topic has been viewed 23220 times and has 41 replies
Hi
I want to deploy sweethome3d jar on a server. Please tell me how to do that
Re: Need to deploy on Tomcat serer
What do you mean by deploying sweethome3d jar on a server? You want to try to deploy the online version on a web server? If it's the case, the source code and the search engine of the forum will give you many hints.
Thank you for your reply.
yes of Course. I want to deploy the online version and want to access through a browser. (like - http://www.sweethome3d.com/SweetHome3DOnline.jsp). Please help me to deploy this.
Thank you
Thank you
Thanks for your Hint. I was able to set it up. When I set it up as a desktop application, application doen't allow me to save the designed floor plan. It says "Can't check if home exists".
Please help me.
Please help me.
Appreciate your reply...
Look at the javadoc and how it's deployed on sweethome3d.com. The following threads might help you too:
http://www.sweethome3d.com/support/foru ... hread,1113
http://www.sweethome3d.com/support/foru ... hread,1454
http://www.sweethome3d.com/support/foru ... hread,1435
http://www.sweethome3d.com/support/foru ... hread,2608
There's no other documentation about this subject, but feel free to write one if you want.
Thanks Putybert.
Hi Mr Puybaret
I want to load the Floor Plan directly. All Parameters should be set internally. Please tell me how to do it.
Thank YOu
Thank YOu
You should set the floor plan you want in the applet parameter named defaultHome.
