confused High priority Deploy extracted sh3d file in web application tomcat
This topic has been viewed 2996 times and has 5 replies
workvaani
Post by workvaani »
I have done the following configuration:
1. In sweetHome3d applet html file, set the parameters as below:
var parameters = {java_arguments:"-Xmx512m", readHomeURL:"%s", defaultHome:"demo"};
2. In the web application - extracted folder having contents of a demo.sh3d
When I run the application I get below error - stack trace:
I have tried adding different url's like file:/// [complete path] or http:// [folder] server path but still it is not able to open the extracted home folder. Please guide???
com.eteks.sweethome3d.model.RecorderException: Can't read home from demo
at com.eteks.sweethome3d.applet.HomeAppletRecorder.readHome(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController$22.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1.run(Unknown Source)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.EOFException
at java.io.ObjectInputStream$PeekInputStream.readFully(Unknown Source)
at java.io.ObjectInputStream$BlockDataInputStream.readShort(Unknown Source)
at java.io.ObjectInputStream.readStreamHeader(Unknown Source)
at java.io.ObjectInputStream.<init>(Unknown Source)
at com.eteks.sweethome3d.io.DefaultHomeInputStream$HomeObjectInputStream.<init>(Unknown Source)
at com.eteks.sweethome3d.io.DefaultHomeInputStream.readHome(Unknown Source)
... 12 more
Thanks!!,
Vaani
Re: Deploy extracted sh3d file in web application tomcat
If defaultHome is "home", then readHomeURL should be "%s.sh3d", no?
workvaani
Post by workvaani »
Thanks that works - but please confirm is it possible to use an extracted sh3d file and reference the folder name in the value of defaultHome? If yes - what configurations are required?.
Regards,
Vaani
What do you mean by "extracted sh3d"???
workvaani
Post by workvaani »
I had used 7zip to extract contents of sh3d file to a folder. Could these contents be used instead?.
No. Even if a sh3d file is based on zip format, don't extract the files it contains, it won't work with Sweet Home 3D.
