angry How to turn wall into round
This topic has been viewed 2885 times and has 6 replies
mnadeem
Post by mnadeem »
Hi i can not turn wall in to round with mouse in any degree ,
Re: How to turn wall into round
As indicated in the help and in the FAQ, you should keep pressed the ctrl key (or alt key under Mac OS X) while clicking at the end point of a wall. The arc extent of the round wall will depend on the point where you'll click the next time.
In case it's too complicated for you, you can also change it afterwards with the modification pane of a wall.
mnadeem
Post by mnadeem »
THanks its works , we doom bin i shoulsd have readen the pdf file ,, thanks any way thats why the expert are there .
So jets other ?: can i png and bmp file convert or put into my list of things if so then how
If you mean Is it possible to import the picture of a piece of furniture and make it appear as a 3D object?, no it's not possible. But you can use a simple box, and apply the image you want on its faces after importing your image as a texture.
mnadeem
Post by mnadeem »
Hi i did not understand what you have mention ,, please advise
Second , i have try to take pic or mov can not do it comes (x) cross . Where i am making wrong , need any plugins , i have latest version v3.7
mnadeem
Post by mnadeem »
Hi i have found that if there is import background image then if it is not properly adjest . photo or video will not be taken . But my ? is how can we know what kinds of images is running becouse in list such thing is not present
again thanks in regards
Users browsing this forum: Bing [Bot], Semrush [Bot]
