Hi - I have a few towers on a castle like building. How can I place a roof so that it goes around the circular tower if the tower is higher than the roof? Thank you.
Earl
roof around a round wall
This topic has been viewed 3199 times and has 7 replies
- Daniels118
- Country: Italy
Re: roof around a round wall
Do you mean something like the lower roofs of these towers?
Thank you for your reply. Not exactly. I have a few gable roofs up against some circular towers. So it’s like a slanted roof rectangle meeting the circular tower which goes up higher.
I assume you want the roof to not intrude into the towers internal space? If so, then I don't think there is a way currently without breaking out into a modelling tool. Dorin's roof plugin gets close, but at the moment cannot do gables I think, only hipped (slopes on all sides). It is probably quicker and easier to layout in SH3D, then export the objects and do some boolean cuts to cut the tower shape out of your gable roof in a modelling tool. Then import that new roof object back into SH3D.
Here's a simplistic blender example using booleans to make the tower cutout the roof and walls of the gabled section:
https://drive.google.com/file/d/1-Tp1Aa ... sp=sharing
As you move the tower, the bit removed from the gabled section is removed as appropriate.
One word of warning: If you reimport previously exported walls, they no longer behave like walls in SH3D. So you probably only want to reimport the roof part if possible once you figure it all out.
How do you open the .blend file?
You need the application blender available at https://www.blender.org/How do you open the .blend file?
