White Space Between Grass & Sky
This topic has been viewed 8509 times and has 17 replies
jibbyjibs
Post by jibbyjibs »
Hey Guys & Girls. Hoping you can help with this one. I almost have my house design close to done, but can't figure out how to fill in that white space between the ground and the sky. When I do my video, I'd like to be able to show an outside view, but not with that white space there. Any tips and tricks would really be appreciated.
Re: White Space Between Grass & Sky
I really don't understand how this could happen in recent versions of Sweet Home 3D. What version do you use?
jibbyjibs
Post by jibbyjibs »
I'm using version 3.5 Java web start Java version 1.6.0_29. I made a 30 second (low quality) video to show what I'm talking about.
I don't think I can attach it here on this forum so have e-mailed it to you instead. When I take the view right down to the ground, it helps somewhat, but this isn't an angle I want to use.
An e-mail from TranquilityLodge in your inbox is from me.
I hope you can help!
The zone shown around the garden is white because you didn't change the ground color or texture in the 3D view modification dialog box.
jibbyjibs
Post by jibbyjibs »
Simple as that... :D Thank you so much, Emmanuel!! Problem is solved.
speed777777
Country: johannesburg, south africa
Post by speed777777 »
hi emmanuel i was using 3.5 java exec and now 3.6 java exec and still have this problem with the white line on the horison, even though 3d view ground texture has been set to grass and the other to sky. could this be the version i am using, or something else. cheers shaun.
How large is your home?
speed777777
hi emmanuel all the houses i do are rather large over 500 megs, but under 1 gig. cheers shaun
speed777777
hi emmanuel hope you well any ideas yet. cheers shaun
By "large", I didn't mean "file size" but "house size" (in a length unit) [;)]
