White sky
This topic has been viewed 3043 times and has 2 replies
pabloyepes
- Country: Houston, Texas, USA
White sky
I am using version 4.1 on Linux. When I render an image of the whole building with an aerial view in level 4, the sky always comes out white. In the 3D properties I tried to use a texture of various skies, and using just a dark blue color. In all cases, on the rendering the sky looks white. I have also changed the brightness, but it does not change the result. Any ideas?
Re: White sky
I guess it's white because you view a part of the generated sky in direction of the sun.
As stated in the help:
So try to use a texture image for the sky.If you selected a color for the sky in the 3D view pane or if the current mode is Aerial view, a sky image computed according to the hour of the day is used for the rendering of the sky. If you chose a texture for the sky, that texture will always be used in Virtual visit mode whatever the selected hour.
pabloyepes
Re: White sky
I also tried with a texture, but it still shows a white sky. Any other ideas?
Thank you
Thank you
