fill space in between internal/external walls
This topic has been viewed 4257 times and has 5 replies
andreab82
Post by andreab82 »
I drew the external walls from the floor plan. Then I created the rooms with internal walls. Now I find myself with massive gaps which are not nice to look at.
Here is what I'm talking about: https://ibb.co/PMsczB2.
It's an old house, so some walls are very thick (60/70cm).
Also, as you can see form the pic the thickness is not consistent.
Continuously changing the wall thickness wasn't very convenient.
In summary, is there a way to fill the space in between?
The only alternative I can think of (to fix this after the fact) is to set the wall thickness to something average (eg 25cm) and draw layers and layers of walls filling the gaps. It should work, I just thought it's not a very elegant solution.
Thanks in advance for any suggestions.
Regards,
Andrea
Country: UK
Re: fill space in between internal/external walls
Post by Mike53 »
You could try this
Create a level 5mm below the height of your wall with the floor thickness set to 5mm
draw walls to fill in the gaps
create a texture, something like "Paint" draw black diagonal lines on it
import the texture and use it as the floor texture
remember to un-check the box's for area and ceilings when modifying the room.
Here is a very quick attempt
andreab82
Post by andreab82 »
Hi Mike53,
If I understand what you suggest correctly, walls will still be empty in the 3D view though.
Thanks for your input.
Regards,
Andrea
andreab82
Post by andreab82 »
am I right that there is no other way then? :-/
Country: UK
Post by Mike53 »
Give it a try with any colour or texture applied to the "room" then check the 2 and 3d views
And why not simply drawing an additional thick wall to fill the space. Walls with the same pattern which overlap are drawn in the plan as it was only one wall.
You could also look at this tip.
