Video renderin speed low
This topic has been viewed 4054 times and has 7 replies
Clovis
Post by Clovis »
I tere
First my keyboar is defective I do not ave two letters workin .
I bout a new computer to render fast my videos on Sweetome3d, bot te speed stills low.
I ave a ood macine now
Its a I7 2600K, wit 8B of ram
And te videos stills take only a litle bit less tan my previous macine, wit was realy slow (core 2 Duo 1.6 wit 2B o mem.)
Te instalation is new, clean, only W7 64, firefox and java
Wat can be wron wit it?
Tks
Clovis
Re: Video renderin speed low
What quality level do you use?
Clovis
Post by Clovis »
Te quality is te same on te two atempts, te second macine sowld be very faster, but its not.
Clovis
What is your file size?
How many light sources does your design have?
Do you have trees or plants in your design?
In the photo creation dialog, what quality do you use? 1, 2, 3 or 4?
Clovis
Post by Clovis »
I'm triin to do a ood quality video. I know it will take a lon. Te question is
Wy te new macine is not too faster ten te old one, its a realy ood macine, asnd I bout it for tat, to mke te animation faster tan te old one.
Te film is 50s lon, wit 1300 frames, quality is 4 and tere is about 12 lit spots onte cealin.
te size is 320x240 25 frames.
I updatyed te java foa a 64 v ersion and stills slow
Clovis
Clovis,
If you want, [url=mailto:[email protected]]send me[/url] your file, and I will make a test render.
Clovis,
Before doing a test render on your file, I made a few changes. I decreased the number of lights from 11 to 6, because that would speed up rendering, while still allowing enough light.
I did the render on a computer with two cores running Ubuntu 11.10, and 2GB of RAM allotted to SH3D. No other processes were running that consumed a lot of computer time.
Check this paragraph in the FAQ to learn how you can allot more memory to SH3D.
How can I adjust the memory used by Sweet Home 3D?
The initial estimate of SH3D was that the rendering would take +/- 1h30m; the actual rendering took +/- 1h40m.
The settings were as I found in your file: Q3 at 320x240 pixels at 25 frames.
My guess would be that a rendering at Q4 would take probably 4x as much time.
My guess is that a machine with 4 processor cores should do the render in approximately half the time of my machine.
You may want to check that
- your computer uses all 4 cores
- you don't have a program running at the same time that uses a lot of processor time.
I have sent the modified file and the movie to your email.
