video: the camera goes on rotating on itself - speed regulation
This topic has been viewed 2070 times and has 3 replies
picmau
Post by picmau »
Hi making a video is it possible avoid that the camera goes on rotating on itself. How can I make it go straight from one point of view to another? Is it possible to adjust the speed differently in the various routes from one point to another?
Re: video: the camera goes on rotating on itself - speed regulation
If you want to go straight from a point to another, move only the visitor between two recorded points without rotating it.
Speed can't be adjusted.
picmau
Post by picmau »
Thank you
perhaps the problem Is that I fix the points of view, choosing them among my registered points and not going directly on the point of view and fix it
How Is it possible to select the speed?
Thank you
As a point of view records also the visitor angles, this could explain the behavior you got.
Speed can be changed only in source code, i.e. you need to recompile the program to get a different speed. Or maybe use an external program to change the frame rate.
