Total posts in this thread: 226
Posts: 226   Pages: 23   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 844736 times and has 225 replies Next Thread
enkonyito
Although the video file is properly saved and playable, sometimes an error message indicates the contrary. sad
It would seem that the saveVideo method can not be used for direct saving of file.
Changes will be made after the release of SweetHome3D-5.5 to verify compatibility of the plug-in.
EnkoNyito
[Jul 20, 2017, 1:04:47 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Version 1.3
Compatible only with SweetHome3D-5.5 and higher
(lights rotation around a horizontal axis)
For video rendering:
- curved line for camera path (circular arc)
- variable speed according to distance
SH3D camera animation
EnkoNyito
[Sep 11, 2017, 9:02:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
The plug-in supports English and French but it is possible to add other languages based on the ApplicationPlugin_en.properties template.
Based on these instructions , the addition of a language can be done as follows:
1-unzip the PhotoVideoRendering-VERSION.zip file
2-transform the .sh3p into .zip
3-paste your file ApplicationPlugin_LANGUAGE.properties
4-transform the .zip into .sh3p
For any additional language integration directly to the plug-in for future versions, you can contact me .
Attachment ApplicationPlugin_en.properties (4768 bytes) (Download count: 1202) (Translation template)
EnkoNyito
[Edit 1 times, last edit by enkonyito at Sep 14, 2017, 5:49:04 AM]
[Sep 14, 2017, 5:35:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Note to translators.
You can translate the label of parameters (rendering properties) by putting your translation in parentheses and separated from the English keyword by a space.
Example:
RenderingPropertiesView.aAminLabel=antiAliasing.min (\u6700 \u5C0F \u9297 \u92F8 \u9F52):
This structure must be respected otherwise the modifications of the parameters will not be taken into account for your translated file.
EnkoNyito
[Nov 4, 2017, 4:31:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sclee
Thank very much for the help of Enko Nyito, so that the renderer has more choice, I also translated the traditional Chinese and Simplified Chinese,
download: http://sync.hamicloud.net/_oops/scleea/seh
[Nov 5, 2017, 11:16:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Geovani141
Brasil
http://i66.tinypic.com/jruq0l.jpg[/IMG[/img]
Sorry, for my English. I have a problem.
I have version 5.6 of the software and I can not create a photo. I click on create photo and it loads but an error appears on the screen, a small icon with an 'x' in the middle. Before I could create photos normally, but now I have this problem. I even formatted my computer to see if it was memory, but it is not. Please help m e.
[Nov 16, 2017, 3:19:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
[moderated]
[Edit 1 times, last edit by Puybaret at Nov 19, 2017, 9:34:41 AM]
[Nov 19, 2017, 6:30:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Geovani141, this error might happen when the program doesn't have enough RAM to work. Read the FAQ to increase the maximum RAM that Sweet Home 3D can use.
[Nov 20, 2017, 1:57:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Some details about the video rendering.
The curved line path is created automatically when there is a difference in orientation between 2 recorded positions.
The greater the distance between 2 recorded positions, the faster the movement speed.
Conversely, the shorter the distance, the slower the speed.
Practical tip to see the difference between a straight line path and a curved line path.
You can save your path in the standard video panel and then open the video plugin.
Since the positions recorded are the same, some parts of the path may be curved and the speed different depending on the distance.
At the next version! wink
EnkoNyito
[Jan 5, 2018, 7:15:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Version 1.4
  • display a message about plug-in compatibility
  • display a message when closing a rendering
  • added a minimum night brightness (dark level 2)
  • selection, in the simple photo rendering panel, of available LookAndFeels
  • other minor bugs fixes and enhancements
(translation template)
EnkoNyito
[Edit 1 times, last edit by enkonyito at Jan 30, 2018, 2:05:54 AM]
[Jan 30, 2018, 2:02:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
