Total posts in this thread: 226
Posts: 226   Pages: 23   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 843990 times and has 225 replies Next Thread
enkonyito
@Ceciliabr
Just a question: Is it possible to make the image-window wider, f.i. 600px wide? That would be really useful.
Here's how the image display is processed in the default photo panel.
this.photoComponent = new ScaledImageComponent();
this.photoComponent.setPreferredSize(new Dimension(getToolkit().getScreenSize().width <= 1024 ? 320 : 400, 400));
To add additional options, I decreased the size of the image preview and since version 1.4 the size of the panel changes depending on the look and feel chosen.
But to answer your question, yes it is possible to increase the size of the image preview.
EnkoNyito
[Feb 16, 2018, 3:52:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@hansmex
Even better: create the possibility to specify the size of the image preview in Preferences... :-)
I will study the feasibility of the thing so as not to complicate the photo panel too much.
Besides, I hesitated to put the option of the choice of look and feel in the preferences if it was possible.
EnkoNyito
[Feb 16, 2018, 3:55:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Maybe you could make the plugin-window resizable?
That would meet every individual need,
[Feb 16, 2018, 9:56:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ndorigatti
Italia
Heheheh I think it would be though... Java and Swing (programming language and UI components used here) are not the best to support responsive layouts...
I hope it is possible, but I have a few ideas/options for the developer:
- What about changing the Quality bar? we have only 4 options and it is huge, fast and best are taking a lot of space in addition to 1-2-3-4.... Maybe replace 1 and 4 with fast and best and keep 2 and 3 instead of replacing the whole component?
The lookAndFeel (that I did not understand why having that option, but maybe I missed some thread) should be a non frequent option to change (it is less important than picture size or quality, so it could stay in a "secondary" frame like advanced options, why not?
So we could have a new frame with:
Look and feel - Preview Picture Size - Any other option
And, this is completely IMHO, I would put the elapsed time bar under the "Advanced settings / Enhance Brightness" line, just to separate what will change the resulting image and require a stop-create (over that line) and what is modifying in live the UI and the components shown (below the progress bar), like lookandfeel.
Take this as some ideas from a developer that uses SH3D sometimes, and used a lot when planning a new home, so if you think is a stupid idea, feel free to tell it! biggrin biggrin
[Feb 16, 2018, 10:37:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@Ceciliabr
Maybe you could make the plugin-window resizable? That would meet every individual need
Proof by the image.
EnkoNyito
[Feb 17, 2018, 12:05:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@ndorigatti
The goal of the plug-in is to stay visually close to the standard photo panel while providing new options.
Personally, I occasionally use quality level 1 (3D view without shadow) and one of the higher quality levels (3 or 4) with the setting of SunFlow rendering engine.
This option is not related to the rendering but I have integrated it in the photo panel in order to modify the appearance of the interface.
The other solution is to use a script for the installer version as shown here with "-Dswing.defaultlaf=".
Available Look and Feels:
javax.swing.plaf.metal.MetalLookAndFeel
javax.swing.plaf.nimbus.NimbusLookAndFeel
com.sun.java.swing.plaf.motif.MotifLookAndFeel
com.sun.java.swing.plaf.windows.WindowsLookAndFeel
com.sun.java.swing.plaf.windows.WindowsClassicLookAndFeel
This may be possible (see previous central image).
EnkoNyito
[Edit 1 times, last edit by enkonyito at Feb 19, 2018, 7:45:18 PM]
[Feb 17, 2018, 12:20:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mirakels
Maybe make 'quality' a drop down menu... It only has 4 choices so why a slider does not add much functionality
[Feb 21, 2018, 8:28:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
@enkonyito
Resizable is king!
Now the next, ( and probably impossible) challenge is: Can the resizable photo renderer include a 3D preview? It would really "revolutionise" this program to have a combined preview- and render-window.
[Feb 25, 2018, 3:57:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Version 1.4.1
- resizable photo panel with modified layout
- display of the current version of the plug-in in the menu
Thanks to my beta testers Ceciliabr and hansmex for their feedback and to Emmanuel Puybaret for his advice! wink
EnkoNyito
[Edit 1 times, last edit by enkonyito at Feb 28, 2018, 7:08:32 PM]
[Feb 26, 2018, 7:58:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Resizable renderer with rendering in progress:
cec
[Feb 27, 2018, 1:59:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
