Total posts in this thread: 43
Posts: 43   Pages: 5   [ Previous Page | 1 2 3 4 5 ]
Previous Thread This topic has been viewed 132853 times and has 42 replies Next Thread
Re: Sweet Home 3D 4.5
The second image looks like blurred. Wouldn't you have selected a Depth of field lens rather than the default one?
Sorry, but the new one does NOT include the features of the advanced renderer.
Note also that you can get more control on the renderer using special properties explained here with some tests here.
I'm going back to the old version.
It's up to you. But if you encounter a bug in an old version or miss a feature, please check whether it was fixed or added before reporting it.
[Nov 2, 2014, 3:23:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
WriterBLAlley
I selected the Depth Of Field setting.
The new problem is, when I went back to the old version (3.7) the advanced renderer no longer shows up, even though the files are intact. Either way, all of my work is lost, and I don't have another app that can render my models. (I've tried many, before you start suggesting.)
[Nov 2, 2014, 3:56:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Comparing with the latest version 1.6 of the Advanced rendering plug-in, I really wonder what feature you miss. Please list them here, and I'll tell you how to do.
The last version that fully supported the advanced rendering was the version 2.6.
[Nov 2, 2014, 4:10:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
WriterBLAlley
I miss being able to render a clear image with realistic lights, no a fuzzy one with blown out lights. How do I get my old version back?
[Nov 2, 2014, 4:18:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Use Default lens not Depth of field one, and learn how to set the light power in the new version. Did you prefer silk or glossy rendering?
With a little patience, I'm sure you can get even better result that with the plug-in.
[Nov 2, 2014, 4:42:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
WriterBLAlley
Just tell me how to get the old version that uses the advanced renderer. That's the one I was able to get good results with.
[Nov 2, 2014, 4:42:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
As said before, use version Sweet Home 3D 2.6. Maybe it could work with more recent versions, but it will be up to you to try.
[Nov 2, 2014, 4:44:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
For your information, I just tried successfully the Advanced rendering plug-in 1.6 with Sweet Home 3D 3.7. Maybe you didn't increase the max memory used by the program?
[Nov 3, 2014, 10:13:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
