Total posts in this thread: 5
Previous Thread This topic has been viewed 8738 times and has 4 replies Next Thread
euristeo
Problem with models from Archive3d.net
Good morning,
i have a problem when import 3d models found on archive3d.net( zip file with .3ds and .gms file).
Models looks like total grey or black and not the same the picture of site.
How I import correct this models?
Thank to everybody .
[Jun 15, 2014, 1:28:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Problem with models from Archive3d.net
Please read the FAQ about 3DS files.
[Jun 15, 2014, 2:10:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
euristeo
Thanks for the faster answer.
I resolve the problem for almost file with the FBX converter.
For other file FBX converter doesn't work (not enough parameters).
how can I resolve it?
[Jun 15, 2014, 4:24:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
altsua
I downloaded models from archive3d.net too and had that "not enough parameters" error. I might have found a solution. I did some research, and found out that the FBX converter 2013 is bugged and doesn't convert all files. I downloaded 2012 version from archive like someone told on another forum, and with that I could convert everything from archived3d.net.
[Oct 25, 2014, 10:55:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
As explained in this blog article, the part of the program that handles 3DS file format, the one used on Archive3d.net, was updated in version 4.5. So, first, you should check if you use this version.
Then, if you still have problems, you should know that many 3D models proposed on that web site use texture images, that sometimes are missing or are at format not supported by Sweet Home 3D.
[Oct 25, 2014, 7:10:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
