Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Problem with models from Archive3d.net |
| Print at Sep 6, 2026, 6:07:53 AM | View all posts in this thread on one page |
| Posted by euristeo at Jun 15, 2014, 1:28:39 PM |
Problem with models from Archive3d.net Good morning, i have a problem when import 3d models found on archive3d.net( zip file with .3ds and .gms file). Models looks like total grey or black and not the same the picture of site. How I import correct this models? Thank to everybody . |
| Posted by Puybaret at Jun 15, 2014, 2:10:21 PM |
Re: Problem with models from Archive3d.net Please read the FAQ about 3DS files. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by euristeo at Jun 15, 2014, 4:24:05 PM |
Re: Problem with models from Archive3d.net Thanks for the faster answer. I resolve the problem for almost file with the FBX converter. For other file FBX converter doesn't work (not enough parameters). how can I resolve it? |
| Posted by altsua at Oct 25, 2014, 10:55:25 AM |
Re: Problem with models from Archive3d.net I downloaded models from archive3d.net too and had that "not enough parameters" error. I might have found a solution. I did some research, and found out that the FBX converter 2013 is bugged and doesn't convert all files. I downloaded 2012 version from archive like someone told on another forum, and with that I could convert everything from archived3d.net. |
| Posted by Puybaret at Oct 25, 2014, 7:10:16 PM |
Re: Problem with models from Archive3d.net As explained in this blog article, the part of the program that handles 3DS file format, the one used on Archive3d.net, was updated in version 4.5. So, first, you should check if you use this version. Then, if you still have problems, you should know that many 3D models proposed on that web site use texture images, that sometimes are missing or are at format not supported by Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 6:07:53 AM |
