Total posts in this thread: 5
Previous Thread This topic has been viewed 9911 times and has 4 replies Next Thread
mudworm
Can I change the Origin of the Image?
When I started the plan, I chose the origin to be by the top-left corner of the plot. But now, my remodel project is mainly in the room that's at the bottom right corner. I will always be zoomed in to work on that corner (so I can get the positions right), but every time, I add a furniture piece, it's by default pasted at grid-position 0-0. then I had to zoom out to have the entire plot visible so I can drag the piece close to where I want to put it and then zoom in again. It gets tiring.
So, can I still change the Origin of the Image now that my work is already in progress?
Sweet Home 3D is so cool! I've been playing with it all day!
[Nov 8, 2010, 12:40:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Can I change the Origin of the Image?
Mudworm,
In version 2.6 and version 3.0 you can do this:
- click in the 2D plan window
- on the keyboard do CTRL-A to select everything
- use the arrow keys on your keyboard to move your entire model
If you use version 2.6 and have the Advanced Edit plug-in installed, there is another way, that potentially is more accurate. Read the tutorial on plug-ins for more info and images.
This is how it works:
- in the menu choose Edit --> Resize
- choose Measure --> Percentage
- make sure to check Keep aspect ratio of and keep the 1:1 value there
- in Position click the bottom-right button
- now change Width to 50 and Height will automatically follow
- click OK
While entering the new width, you will see how your entire model shrinks to half size: walls, floors and furniture. Because you chose the bottom-right button, the entire model will shrink in that direction.
Now repeat the procedure as follows:
- in Position click the top-left button
- now change Width to 200 and Height will automatically follow
- click OK
While entering the new width, you will see how your entire model expands again to double size: walls, floors and furniture. Because you chose the top-left button, the entire model expands from that point.
The result is that your entire model moved to the right and downwards. If you have a simple model, it's (relatively) easy to move your model to precise new coordinates. If you have a more complex model, it may take some calculating. Of the nine buttons in the resize widow, click the top-left button and write down the coordinates of the top-left point of the imaginay square that surrounds your model. Then click the bottom-right button, and again write down the coordinates. Using these, you should be able to work out how to move your model in such a way that a wall ends up on specific X,Y coordinates.
I suggest you practice first with something simple, so that you understand how it works.
[Nov 8, 2010, 1:21:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mudworm
Hi Hans, thanks so much for the speedy reply! The simple Ctrl-A & move worked perfectly. I should look into the Advanced Edit Plug-in though (I'm on 2.6) since I'm sure it offers a lot of useful features.
[Nov 8, 2010, 1:27:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mudworm, you should try to place furniture with a drag and drop gesture from the catalog to the location you want in the plan. It's faster and you wouldn't have to move the whole plan...
[Nov 8, 2010, 10:25:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mudworm
Sweet! I learned another trick. smile
[Nov 9, 2010, 1:48:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
