Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can I change the Origin of the Image? |
| Print at Sep 10, 2026, 1:37:13 AM | View all posts in this thread on one page |
| Posted by mudworm at Nov 8, 2010, 12:40:44 AM |
Can I change the Origin of the Image? When I started the plan, I chose the origin to be by the top-left corner of the plot. But now, my remodel project is mainly in the room that's at the bottom right corner. I will always be zoomed in to work on that corner (so I can get the positions right), but every time, I add a furniture piece, it's by default pasted at grid-position 0-0. then I had to zoom out to have the entire plot visible so I can drag the piece close to where I want to put it and then zoom in again. It gets tiring. So, can I still change the Origin of the Image now that my work is already in progress? Sweet Home 3D is so cool! I've been playing with it all day! |
| Posted by hansmex at Nov 8, 2010, 1:21:10 AM |
Re: Can I change the Origin of the Image? Mudworm, In version 2.6 and version 3.0 you can do this: - click in the 2D plan window - on the keyboard do CTRL-A to select everything - use the arrow keys on your keyboard to move your entire model If you use version 2.6 and have the Advanced Edit plug-in installed, there is another way, that potentially is more accurate. Read the tutorial on plug-ins for more info and images. This is how it works: - click in the 2D plan window - on the keyboard do CTRL-A to select everything - in the menu choose Edit --> Resize - choose Measure --> Percentage - make sure to check Keep aspect ratio of and keep the 1:1 value there - in Position click the bottom-right button - now change Width to 50 and Height will automatically follow - click OK While entering the new width, you will see how your entire model shrinks to half size: walls, floors and furniture. Because you chose the bottom-right button, the entire model will shrink in that direction. Now repeat the procedure as follows: - click in the 2D plan window - on the keyboard do CTRL-A to select everything - in the menu choose Edit --> Resize - choose Measure --> Percentage - make sure to check Keep aspect ratio of and keep the 1:1 value there - in Position click the top-left button - now change Width to 200 and Height will automatically follow - click OK While entering the new width, you will see how your entire model expands again to double size: walls, floors and furniture. Because you chose the top-left button, the entire model expands from that point. The result is that your entire model moved to the right and downwards. If you have a simple model, it's (relatively) easy to move your model to precise new coordinates. If you have a more complex model, it may take some calculating. Of the nine buttons in the resize widow, click the top-left button and write down the coordinates of the top-left point of the imaginay square that surrounds your model. Then click the bottom-right button, and again write down the coordinates. Using these, you should be able to work out how to move your model in such a way that a wall ends up on specific X,Y coordinates. I suggest you practice first with something simple, so that you understand how it works. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by mudworm at Nov 8, 2010, 1:27:08 AM |
Re: Can I change the Origin of the Image? Hi Hans, thanks so much for the speedy reply! The simple Ctrl-A & move worked perfectly. I should look into the Advanced Edit Plug-in though (I'm on 2.6) since I'm sure it offers a lot of useful features. |
| Posted by Puybaret at Nov 8, 2010, 10:25:21 AM |
Re: Can I change the Origin of the Image? mudworm, you should try to place furniture with a drag and drop gesture from the catalog to the location you want in the plan. It's faster and you wouldn't have to move the whole plan... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mudworm at Nov 9, 2010, 1:48:50 AM |
Re: Can I change the Origin of the Image? Sweet! I learned another trick. ![]() |
Current timezone is GMT Sep 10, 2026, 1:37:13 AM |
