Print at Sep 10, 2026, 1:37:28 AM
Posted by hansmex at Nov 8, 2010, 1:21:10 AM
Re: Can I change the Origin of the Image?
Mudworm,
In version 2.6 and version 3.0 you can do this:
- click in the 2D plan window
- on the keyboard do CTRL-A to select everything
- use the arrow keys on your keyboard to move your entire model
If you use version 2.6 and have the Advanced Edit plug-in installed, there is another way, that potentially is more accurate. Read the tutorial on plug-ins for more info and images.
This is how it works:
- in the menu choose Edit --> Resize
- choose Measure --> Percentage
- make sure to check Keep aspect ratio of and keep the 1:1 value there
- in Position click the bottom-right button
- now change Width to 50 and Height will automatically follow
- click OK
While entering the new width, you will see how your entire model shrinks to half size: walls, floors and furniture. Because you chose the bottom-right button, the entire model will shrink in that direction.
Now repeat the procedure as follows:
- in Position click the top-left button
- now change Width to 200 and Height will automatically follow
- click OK
While entering the new width, you will see how your entire model expands again to double size: walls, floors and furniture. Because you chose the top-left button, the entire model expands from that point.
The result is that your entire model moved to the right and downwards. If you have a simple model, it's (relatively) easy to move your model to precise new coordinates. If you have a more complex model, it may take some calculating. Of the nine buttons in the resize widow, click the top-left button and write down the coordinates of the top-left point of the imaginay square that surrounds your model. Then click the bottom-right button, and again write down the coordinates. Using these, you should be able to work out how to move your model in such a way that a wall ends up on specific X,Y coordinates.
I suggest you practice first with something simple, so that you understand how it works.
