Total posts in this thread: 19
Posts: 19   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 24173 times and has 18 replies Next Thread
kumax
Re: My photos on the wall..
Thanks for the nice comment! blushing
___________
Another render for my another friend. Big photo print on the wall.
I wish the quality of shadows and textures would be better but the floor is perfect!! applause Thank you advanced photo render. wink
[Oct 5, 2010, 10:59:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Very nice. smile
I'm looking forward discovering the picture you'll submit to Sweet Home 3D contest. 6 days left before the end! wink
[Oct 5, 2010, 11:22:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
db4tech
Another great looking render! smile
What is it about the shadows that you'd like to change, the hardness? Also the textures?
db4tech
[Edit 1 times, last edit by db4tech at Oct 6, 2010, 10:14:50 PM]
[Oct 6, 2010, 10:13:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sanjoyp
Hi sorry for the thread hijack. I am running in to problems with my photos I have made into paintings on the wall ? I have found that those taken from gifs are okay but when the jpg resolution is high 2000+ * 2000+ pixels I am unable to render. I get the dreaded red x, memory issue ?
This image has two boxes with customer textures which are iphone photos of paintings.
Is it just lack of RAM ?
[Oct 7, 2010, 1:13:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sanjoyp
Which floor texture did you use in this photos it is exactly what I am after!
[Oct 7, 2010, 1:15:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sanjoy,
There's some kind of an upper limit to the size of texture you can use.This problem has been reported before (see this thread). The solution is to make your texture smaller.
A remark about texture size: If you make a render of 4000x3000 pixels and there's a picture on the wall (see the two pictures in your last post) then the size of the pictures on the wall is maybe 800x600 pixels. Why would you apply a texture of 2400x1800 pixels (or something similar) only to have it reduced in the final result to 800x600? It takes up a lot of processor time to calculate every pixel, but none of it shows as a better quality in the final result.
[Oct 7, 2010, 1:34:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sanjoyp
Good point Hans, I was using the train of thought of not removing any detail I had and using the high res imaged. Will retry.
Cheers
Sanjoy
[Oct 7, 2010, 1:40:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kumax
db4tech
Not the hardness but the smoothness? I don't know how to say it, but I see some dots in the shadow and I would rather like to have it in one smooth surface. I think the thing which would solve my problem it's to render it in bigger resolution and than resize it to smaller picture. But the bigger resolution would kill my computer.. :-))
And the thing about textures.. I meant it would be nice to see some fabric texture of the sofa... for example. :)
[Oct 31, 2010, 12:46:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
whippetsleek
Hi kumax... not sure about the shadows.. that would be puybarets or db4tech's area.. smile but when I want to get a fabric type texture, I used a smaller texture of between 256 x256 or 512x512, and make it the shades very distinct. Then I make the texture very small in the texture editor, like 1 inch sq. Here is an example..
It used this texture at 4x4 inches
This one is a little lighter
and used this at 1x1
And this is dark...
and used this at 6x6 inches
And those were great looking renders! wink
[Nov 1, 2010, 7:26:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
