unable to calculate photo
Hi! I'm having a problem with rendering. When I launch the "create 3D photo" function, a red X appears in the window shortly afterward, saying "unable to calculate photo." Help! Thanks...
Re: unable to calculate photo
Probably not enough system resources available.
See "How can I adjust the memory used by Sweet Home 3D" on the FAQ page to increase the amount of memory Sweet Home 3D is allowed to use.
Italy
Try to create a new project, insert just one model and try to render. If it shows the red X, then the problem is not the available memory. Then post the result here so it will be easier to assist you.
