Previous Thread This topic has been viewed 1716 times and has 2 replies Next Thread
MartinH81
Not perpendicular triangle
Hi
Does someone know how to create a non-perpendicular triangle in sweet home 3d? I got a triangle from a furniture lib, but it is perpendicular.
Bestregards
Martin
[Feb 17, 2024, 9:55:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Not perpendicular triangle
You can rotate the triangle along the X and Y axes. If you need to rotate both X and Y, first set the X, export/import, and then you can set the Y.
Of course you can also use the Generate 3D Shape tool under the Tools menu to generate any shape with 8 or less points. (That's the ShapeGenerator plugin if you haven't installed that yet.)
[Feb 17, 2024, 10:10:27 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You can also create a triangle room at a higher level, export it at OBJ format and import it as a piece of furniture.
[Feb 17, 2024, 10:18:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
