Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Not perpendicular triangle » » » » Post: Re: Not perpendicular triangle |
Print at Sep 28, 2026, 12:47:58 AM |
| Posted by Keet at Feb 17, 2024, 10:10:27 AM |
Re: Not perpendicular triangle You can rotate the triangle along the X and Y axes. If you need to rotate both X and Y, first set the X, export/import, and then you can set the Y. Of course you can also use the Generate 3D Shape tool under the Tools menu to generate any shape with 8 or less points. (That's the ShapeGenerator plugin if you haven't installed that yet.) ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 28, 2026, 12:47:58 AM |
