Print at Sep 15, 2026, 7:55:20 AM
Posts: 197   Pages: 20   [ Previous Page | 11 12 13 14 15 16 17 18 19 20 | Next Page ]
Posted by Puybaret at Nov 5, 2018, 12:00:24 AM
Re: Sweet Home 3D 6.0
What makes you think it's because of the version 6.0? Under what system do you use Sweet Home 3D? What error do you get?
Posted by Jerintho at Nov 11, 2018, 10:25:19 PM
I was first using version 5.7 without any problems (Windows 10 system). After updating to version 6.0, the program crashes as I try to save my drawing. After going back to 5.7 everything works great again...
I will try to uninstall first and re-install 6.0. I hope it will be fixed then.
By the way, love your stuff!!
Posted by Jerintho at Nov 11, 2018, 10:41:22 PM
Made a fresh install, everything works great now!
Posted by dorin at Nov 21, 2018, 9:26:39 AM
WARNING For those who usually modify the look and feel.
Same features of the v.6.0 may not work because of this.
E.G.
I use
-Dswing.defaultlaf=javax.swing.plaf.nimbus.NimbusLookAndFeel
With this option the math formula in number box are not processed.
Without this (original file) it work perfect.
Posted by Raevlav at Nov 21, 2018, 7:38:02 PM
sorry guys if this is not the proper topic or these problems have been already discussed.
After upgrading to v.6 'Catalog icons' option of 'Furniture icons in plan' in 'Preferences' is not available. So all the models at plan now are shown as top view icons.
Also two lowest (fastest) qualities in 'Create photo' are not available too (the slider just cannot be moved to the corresponding positions).
Posted by Kunda at Nov 28, 2018, 6:43:39 PM
@dorin can you provide a screenshot of what the end result of modifying the look-and-feel of SH3D looks like ?
Posted by dorin at Nov 29, 2018, 9:23:11 AM
Is not a big deal only look a little bit better
The standard:
The nimbus:
Remember the Warning: with this look-and-feel setting some function DON'T work. I've discover at this moment only the math formula issue but could be more other.
Posted by maureenowaters at Oct 13, 2019, 9:48:58 AM
So beautiful, just love it.
Posted by 3DMR at Feb 3, 2023, 12:07:01 PM
Hi Puybaret, I managed to open and close a door with Blender.
In SweetHome I can now see the option (Modify opening) but the textures of the door and hinges are transparent after exporting them (OBJ) from Blender.
(The door frame is not transparent).
What should I do to make the textures solid ?
Posted by 3DMR at Feb 3, 2023, 3:25:22 PM
Hi Puybaret, Found it and I'm a little embarrassed, I forgot to look at the "normals" in Blender, they weren't all facing out. Sloppy of me but maybe someone else can benefit from the "solution".
