When i try to render my sweethome 3d
i try different settings at Q3 and Q4
every time i save the resulted photo that is good
But i must record the settings every time even in photo name.
is there way to SAVING RENDER SETTINGS AUTOMATIC to return to it again.
thank you very much for this excellent application.
This topic has been viewed 8660 times and has 5 replies
mostafanasr
- Country: egypt
Re: SAVING RENDER SETTINGS AUTOMATIC
Hi mostafa,
Whether with the AdvancedSettings_PhotoRendering-1.3.1 plug-in or the Rendering properties action of the PhotoVideoRendering-1.8 plug-in, the rendering settings of a project are saved after modification.
For a new project, the plug-ins find either the default values or the custom values in a file for the installer version of Sweet Home 3D.
You will find more information in this document.
Enko
Enko
EnkoNyito
mostafanasr
- Country: egypt
Hi enkonyito,
first, thank you for your answer.
i need text file for render settings show me all settings i used for every render.
To know which file to edit according to your system, refer to this FAQ on increasing memory.i need text file for render settings show me all settings i used for every render.
Regarding the rendering settings, just add [font=courier new]-Dcom.eteks.sweethome3d.j3d.PhotoRenderer. [/font] in front of the properties of this file by modifying the default values.
(lowQuality: Q3; highQuality: Q4)
EnkoNyito
mostafanasr
- Country: egypt
thanks enkonyito,
i will try it
i will try it
mostafanasr
- Country: egypt
thanks enkonyito,
i will try it
i will try it
