Disappearing menus in Mac OS 10.4.9
This topic has been viewed 3553 times and has 1 replies
ohmann
Post by ohmann »
I'm running Sweet Home 3D under Mac OS 10.4.9. Whenever I open up an additional menu window (in order to modify a wall, a furniture etc.) and I start to move the mouse, the window dissapears so that I can't change anything or proceed otherwise (i.e I also cannot return to the main window). I have to forcequit the programm and start anew. Such it is completely impossible to work with the programm. Are there any known issues, that means conflicts with other installations?
Help would be very much welcomed.
Thanks.
Re: Disappearing menus in Mac OS 10.4.9
Thank you for your report. Miserably you're the first person to mention this issue.
Sweet Home 3D requires only Java and OpenGL, so if it's a conflict problem, check around this.
Maybe you should upgrade your system to 10.4.11...
