Problems with version 4.3 and Java 7 on Mac OS X 10.8
This topic has been viewed 3812 times and has 2 replies
the_patcher
Post by the_patcher »
is it possible to run Sweet Home 3D version 4.3 with Oracle Java 7 installed on Mac OS X 10.8.5?
Currently when I try to start the local application, I get a dialog saying I have to download Java 6 from Apple.
But Oracle JRE 7 is already installed on my system as you can see from the terminal output:
~$ java -version
java version "1.7.0_51"
Java(TM) SE Runtime Environment (build 1.7.0_51-b13)
Java HotSpot(TM) 64-Bit Server VM (build 24.51-b03, mixed mode)
~$ whereis java
/usr/bin/java
Java is the browser is disabled through the Java control panel.
Any help is appreciated :)
Re: Problems with version 4.3 and Java 7 on Mac OS X 10.8
You should use the Jar executable version of Sweet Home 3D. To ensure that the max memory setting will be enough, run it with the following command in the Terminal:
java -Xmx2048m -jar [i]/path/to/[/i]SweetHome3D-4.3.jar
To get the path of SweetHome3D-4.3.jar file, simply drag and drop the file from the finder to the Terminal window.
the_patcher
Thank you very much :)
I was blind ;) when I checked the files section on sourceforge yesterday.
